shadow5837's avatar
shadow5837
Wifi Extender in the Access Point mode
I am using the Netgear Wifi extender model EX6150 v2 with the side switch in the Access Point position, connected to my router with an ethernet cat 6 cable.
 This is extending my wifi signal to my nest cameras, however it inicates that it is an unsecured wifi signal?
Can I do something with the unit to correct that?
If I were to change the side switch position to Extender, and not use the direct cable connection, I believe it will produce a secured signal.
The difficulty is in that setup it does not send the wifi signal as far as I need.
Thanks for whatever advice you can offer.
