B-3Kids
Sep 04, 2018Tutor
Wifi Extender loses connection hourly.
Why does this extender lose connection after a couple of hours every day? I have to reset through WPS if I need to use it. The unit is less than 25 feet from the main router. There is no barrier betw...
Sep 05, 2018Guru - Experienced User
How are you wanting to use it? To extend ethernet to a device that doesn't do WiFi? Or are you wanting to do something else?
Are you using FastLane? Are you using the one WifI name feature?
Also, what is the router manufacturer/model?
