Youngwindle's avatar
Youngwindle
Wifi extender n300 incorrect password message
When I select the.ext on a device during set up and put in the existing router password as suggested it says 'incorrect password'. It isn't so What do I do?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Youngwindle
    I would log into your Extender by going to www.mywifiext.net and then changing the password to what you want it to be.
    DarrenM
  • Can't change password as not accepting the wifi router password as the correct old one. Help!
