pennyknap
Jan 13, 2018Follower
Wifi extender N300 model EX2700 wont connect to my Samsung tablet
I set up my N300 model EX2700 successfully and connected my Samsung tablet. It worked ok but when I tried to connect the tablet to the extender 2 days later it will not connect. It shows up on my tab...
jvasanth1984
Mar 10, 2018Virtuoso
eddie-kvs
Mar 11, 2018Aspirant
jvasanth1984wrote:Try to perform network power cycle and check if it works.
Believe it or not, I'm not a neophyte. I performed a hard reboot on the host modem/router and then powered the wifi extender. Of course I rebooted the Samsung devices and even reset the the devices so that all connections were purged, purged the partition cache just "finger cross" measure. No joy, no connection.
So what's next... other than elementary steps?
-Eddie
- jvasanth1984Mar 11, 2018Virtuoso
Hi eddie-kvs,
Did you tried modifying wireless channel on your Router? What firmware version are you running on the extender? What security type do you have on the Router? Does Router LED Green when you come across this issue?
