Mathias1976's avatar
Mathias1976
WIFI Extender needed
Looking to add a WIFI extender to my router. I have it located in the middle of my house and need to extend the range about ten feet to the edge of my garage. i bought a the NETGEAR WIFI AC1200 extender but it is not compatible with my router,
What should I be using instead. I am not a techie guy.
but any help is better than no help.
  • schumaku's avatar
    schumaku
    The extenders are universal, at least when the common WPA2-PSK is used, and the regulatory area for the router and extender are matching, so the extender (and all Wi-Fi devices) is able to deal with the 2.4 GHz and 5 GHz channels configured on both units.
    Let us know where the idea is coming from your router should not be compatible. Make and model of the router?
    • Mathias1976's avatar
      Mathias1976
      the Nighthawk app says that is is not compatible with the extender i had purchased.
      I just need to know which one is compatible with my Nighthawk x4s ac2600 WIFI router.
      i have read a couple of other community conversations and don't want to get the wrong one.
      • schumaku's avatar
        schumaku
        Be a little bit more informative which Netgear Extender - the model is certainly on the product label - should not be compatible with the Nighthawk App.
        This would be an example of  product designation we can work with. Now back to this unknown AC1200 Extender. Note: Apps are not the center of the universe. Every Netgear extender can be installed using "Connect with WPS " or "Connect with the NETGEAR Installation Assistant" - no fancy app required.
        Head to https://www.netgear.com/support/ - type in the model number or the product designation and you get access to the Product Data Sheet, the Installation Guide, and last but not lest the User Manual.
