Sk8
Jun 25, 2016Aspirant
WiFi extender Nighthawk EX7000 won't connect to the network wireless or with ethernet
I've tried all the steps I can find on line to get my extender to connect to the network but even sitting physically next to it using the WPS and a direct ethernet connection it won't.
- Jul 24, 2016
Well, put it down to experience - Don't buy refurbished Netgear products.
Sk8
Not sure. I put it in the same room and pushed both WPS buttons and nothing happened. Tried again with Ethernet cable and nothing happened. The 2 band signals stay amber and the connection arrows blink green when i plug it in and never change and it doesn't show up on my wifi list to connect to.
Sk8
Jul 24, 2016Aspirant
Apparently it's just a crappy extender that doesn't work. Unfortunely it took so long to try and work with it to get it to work and since you can't actually contact Netgear to talk to a person now there's no warranty and nothing I can do but eat all the money and hours I spent trying to get it to function. Very Unhappy!!!
