Sk8
Jun 25, 2016Aspirant
WiFi extender Nighthawk EX7000 won't connect to the network wireless or with ethernet
I've tried all the steps I can find on line to get my extender to connect to the network but even sitting physically next to it using the WPS and a direct ethernet connection it won't.
- Jul 24, 2016
Well, put it down to experience - Don't buy refurbished Netgear products.
sktn77a
Jul 24, 2016Virtuoso
Well, it should work. Call tech support (you may need to register the unit first) and then go through the troubleshooting routine with them. If they can't get it to work, get a warranty replacement.
