Sk8
Jun 25, 2016Aspirant
WiFi extender Nighthawk EX7000 won't connect to the network wireless or with ethernet
I've tried all the steps I can find on line to get my extender to connect to the network but even sitting physically next to it using the WPS and a direct ethernet connection it won't.
- Jul 24, 2016
Well, put it down to experience - Don't buy refurbished Netgear products.
Sk8
Jul 24, 2016Aspirant
I can't call tech support because it won't let me register it. It says the unit was already registered. I bought it refurbished and it looks like the previous owners had the same problem. They probably bought it, wouldn't work, registered it to get tech support and then returned it. Now I can't do anything with it and it obviously wasn't repaired correctly. Unfortunately since I spent so much time trying to make it work now the place I bought it won't take it back either.
- sktn77aJul 24, 2016Virtuoso
