am_20
Dec 29, 2018Aspirant
Wifi extender not connecting to internet
Hi guys,
I have an EX6200 AC1200 wifi range extender producing a 2.4GHz and a 5GHz network, both of which recently stopped working on my Mac computers (which are running macOS Mojave). My macs ...
Dec 31, 2018Guru - Experienced User
Can you tell us what IP address you are seeing in the Mac? This guide might help: https://support.apple.com/guide/mac-help/find-your-computers-name-and-network-address-mchlp1177/mac
am_20
Dec 31, 2018Aspirant
Hi Stephen,
This is the IP when connected to the main network:
And this is the IP while on the extended network:
*There is no router number, but I don't know why
- StephenBDec 31, 2018Guru - Experienced User
DHCP is failing when you are connected to the extender. The Mac is assigning itself an IP address (169.254.x.x. addresses are self-assigned). The router field is empty because the Mac doesn't know what to fill in there.
Can you try clicking on the "renew DHCP lease" control when you are connected to the extender network, and see if it gets a 192.168.1.x address.
- am_20Jan 01, 2019Aspirant
Hi Stephen,
Thank you for the recommendation. I renewed the DHCP lease, but the IP address remained self-assigned.
- StephenBJan 01, 2019Guru - Experienced User
You could try assigning a 192.168.1.x static address, and see if that works. That would isolate the problem to DHCP, and not raw connectivity.
But you really are better off using DHCP. Hopefully DexterJB or Christian_R can help.
