Kevelstone
Aug 14, 2018Aspirant
wifi extender not visible on windows 10
Can anyone advise, my new wifi extender is not being detected on my windows 10 machine, i have successfully connected on my linux and android devices but it is not showing up on my windows 10 device
Aug 14, 2018Guru - Experienced User
Are you seeing other wifi networks on the Windows 10 system?
- KevelstoneAug 14, 2018Aspirant
yes all other networks are still visible, not sure if there is anything that needs enabling on the network adapter
- StephenBAug 14, 2018Guru - Experienced User
If the PC is within range of the WiFi then it should be seeing the network. Are you using the normal Windows facilities to connect?
yes i am using the standard windows connection, i can connect it to the same router that is feeding the extender but not the externders signal itself
