Kevelstone
Aug 14, 2018Aspirant
wifi extender not visible on windows 10
Can anyone advise, my new wifi extender is not being detected on my windows 10 machine, i have successfully connected on my linux and android devices but it is not showing up on my windows 10 device
Kevelstone
thats what i was thinking, was looking ot post here as if there might have been any tweaks i need to make on my apaters end, i have tried adding manually to no avail but i will look inot a wifi analizer tool
Aug 14, 2018Guru - Experienced User
When you figure it out, please post back with the solution!
- KevelstoneAug 14, 2018Aspirant
if anyone has any other suggestions feel free to post
- DexterJBAug 19, 2018NETGEAR Moderator
Hi Kevelstone,
1. What is the firmware version of the extender?
2. Have you tried changing the wireless channel?
3. Have you tried re-installing/rolling back the drivers for the adapter?
Dexter
Community Team
- DexterJBAug 23, 2018NETGEAR Moderator
Hi Kevelstone,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
