Alexjormac
Dec 09, 2015Follower
Wifi Extender password
Hello, I just bought the EX2700 N300 WiFi Range Extender and I have set it up without a problem but can´t connect to it because it doesn´t accept the password of my modem and the instructions said that I should use the same password. I have try reseting the extender and reseting my modem 2 times but still can´t connect to it. Can someone please help me with this? Thank You very Much! Alex.
1 Reply
- Babylon5NETGEAR Employee Retired
Are you using simple alphanumeric characters in the passphrase? Have you tried temporarily changing to a very simple passphrase e.g. 1234abcd?
What is the manufacturer and model number of the modem?
