cokashi232
Apr 01, 2022Follower
Wifi extender problems
so basically i have my computer setup on the other side of the house to the wifi, so I use the netgear extender, the range meter is always on red but i get 40 ping so i didn't mind, but when i woke u...
kmiller000
Apr 07, 2022Aspirant
what is your question.? you only mentioned the issue you are having.
There might be several reason behind that , som of them might be the standard of the devices you are using. for simple you can change the distance at your place. Or you can also buy standard extender or router.
