Bellancott
Dec 15, 2022Follower
WiFi extender setup AC1750
New unit now connected to router, but no internet access. Must have missed a step somewhere..... Anyone with a solution would be appreciated.. 4 led on front - 2 on, 1 off, 1 on (from left hand side)....
Dec 15, 2022Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
