Bellancott
Dec 15, 2022Follower
WiFi extender setup AC1750
New unit now connected to router, but no internet access. Must have missed a step somewhere..... Anyone with a solution would be appreciated.. 4 led on front - 2 on, 1 off, 1 on (from left hand side)....
Imyourangel0104
Dec 19, 2022Aspirant
Once you get the netgear extender powered on, go to settings and connect to netgear_EXT. It will show no connection. Open safari type in the IP address of the extender. It will open up a page, it will have set up extender, follow the instructions it will be really easy from there. Then you can move it to where you need the boost the most, give it a few minutes to start back up.
good luck.
