bermbos19
Sep 01, 2018Aspirant
WiFi extender setup not completed
I am in the middle of the set up of the wifi extender where I'm told to connect my devices to the new extender, when it timed out and I can not get back to that page to know what to do next. Is the ...
Sep 02, 2018Guru - Experienced User
Look for the extender's IP address in your router's attached device list. Then enter that IP address in your browser. That should bring you to the extender's web page, so you can review the setup.
- bermbos19Sep 03, 2018Aspirant
Thank you for the help, but I don't know how to locate my router's attached device list. I've looked around in the control panel under the wireless network, but I did not see anything that said attached device list. Though the extender appears to be working very well, I'm thinking that knowing its IP address would be important at some point.
- StephenBSep 04, 2018Guru - Experienced User
It would be on the router's web page, not in the Windows control panel.
What router do you have (manufacturer and model)?
- bermbos19Sep 09, 2018Aspirant
Oh. I have an AC2200 Nighthawk X4 Wall-plug Range Extender(EX7300)
