NiganKhan's avatar
NiganKhan
Follower
Sep 12, 2019
Wifi extender via Ethernet
Hello everyone,,
I have recently built a garden office and have run a cat5 Ethernet cable from my router in my house to the garden office. Can anyone suggest the best Wi-fi extender that can plug into the Ethernet socket which will create Wi-fi in the garden office. Power line extenders don’t work which was why I put in an Ethernet socket. Thanks
1 Reply
  • plemans's avatar
    the best? Usually a triband setup. Basically pick the most expensive extender netgear offers. But I'm betting if its a garden office, it probably doesn't quite need the best, it just needs to meet certain requirements.  A better option would be to go to the netgear extender page and use the options menu on the left to select the features you want/need in an extender. It'll then filter out the ones you don't and leave you a list to choose from.
    Another option would be to utilize a router running in Access point mode. If you've got ethernet ran out there an old router or a new one can run in AP mode and have the same capabilities as an extender in access point mode.
