aworth
Sep 08, 2016Aspirant
Wifi Extender WN3000RPv3
I have been using this extender for several months with no problem. I have a new alarm system and a Vonet wifi bridge which allows the alarm to connect to wifi. If I connect the Vonets unit to the ex...
DarrenM
Sep 09, 2016Sr. NETGEAR Moderator
Hello aworth
Is there maybe a certain bandwidth requirement that the alarm system requires for it to work?
DarrenM
aworth
Sep 09, 2016Aspirant
Hi Darren
It isn't the alarm system itself. Risco supply a wireless bridge to go with it. I am the first person with this problem as I have the Netgear extender
so need to resolve this or I can't get the alarm to work correctly. It works at the momnent but very spuriously.
The info on the bridge is at
http://www.vonets.com.cn/download/VAP11N/VAP11N%20Quick%20Setting%20Guide.pdf
I hope you can help.
Kind Regards
Andrew
