AliP1's avatar
AliP1
WiFi extender WN3000RPv3
I am having trouble connecting devices to the WiFi extender. I have gone through set up multiple times, got the extender connected to the router successfully with all green lights, but when I try to connect a device to it it rejects saying that the password is incorrect. I have tried forgetting the original network and trying again but it still rejects the password. But when I reconnect to the main router with the same password it does so straight away. Can anybody share some thoughts please?
  • Hi Ali, thanks for checking back.
    Page 38 of the user manual linked below provides the steps on how to reset the extender.
    http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_25Aug2015.pdf
    Once this is completed, you can go through the setup/installation as described on the installation guide linked below as well as on the manual linked above.
    http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_QSG_17Aug2015.pdf
    Once completing the setup, check if you are able to connect your devices to the extended network and see if they can go online. If not, the next step would be to use a device that is already connected to the main network (mobile, PC, etc.) and access the web UI (user interface) of your main wireless router. Once you are there, you can check for the attached devices and see if the extender is listed as one of them. If yes, it should have an IP assigned to it. Use that IP address and type it on the address bar to get to the web UI of the extender.
    Dexter
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi AliP1,
    Please factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
    Christian
    • AliP1's avatar
      AliP1
      Hi Christian,
      Thank you for the response to try and help. Unfortunately I did the factory reset and then tried to follow the insructions online, but when I opened the website it said that I was not connected to my EXT (even though my phone said that I was connected). There was no button for setting up a new EXT either.
      I then tried several times to do this process but had the same outcome.
      Following this I tried to do the WPS set up after a factory reset to see if this would have changed anything, to which I was getting the same issue with 'the password is incorrect'.
      So far nothing is seeming to work to try and get this set up and unfortunately when I went to register my device for netgear help I was too late and it wouldn't let me.
      Any other suggestions would be great.
      Thanks
      Ali
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi AliP1, after doing a factory reset, does the extender broadcast the default NETGEAR_EXT network that you connect your device to?
        Dexter
