runBC
Nov 16, 2016Aspirant
Wifi Extender
Have a Nighthawk AC1900 router and just purchased a Nighthawk X4 AC2200 Wifi Extender. Everything appears to be working - router link & client link both green and joining the EXT. However nothing load...
runBC
Nov 17, 2016Aspirant
Reset button and re-install procedure worked. Thanks
michaelkenward
Nov 18, 2016Guru - Experienced User
That's good news. It often helps to start from scratch.
I realised later that I had not suggested using the WPS feature to try to connect devices to the wifi. (Look that one up in the manuals if you aren't familiar with it.)
