runBC
Nov 16, 2016Aspirant
Wifi Extender
Have a Nighthawk AC1900 router and just purchased a Nighthawk X4 AC2200 Wifi Extender. Everything appears to be working - router link & client link both green and joining the EXT. However nothing load...
runBC
Nov 18, 2016Aspirant
WPS is how I'm connecting, however any instances of the wifi extender interfering with the actual router? I'm having intermittent internet disconnects on a PC that's hard wired into the actual router. I unplug the extender and the PC stays connected, plug it back into the wall, it goes out. Frustrating considering it's Netgear router and Netgear wifi extender.
- DarrenMNov 21, 2016Sr. NETGEAR Moderator
Hello RunBC
Are you having Ip conflicts do you notice when the PC goes out in the bottom left hand corner of your screen does a yellow triangle show up over the internet connection?
DarrenM
