TheChosenSphinx's avatar
May 05, 2017
Wifi Extenders and Captive Portal
Can these Wifi Extenders receive, amplify and broadcast/transmit a signal from a public wifi network that is behind a Captive Portal with Web Authentication?
1. NETGEAR Nighthawk AC1900 Desktop WiFi Range Extender (EX7000-100NAS​)
2. NETGEAR AC1200 Desktop WiFi Range Extender (EX6200)
I live in a Public Housing Project that uses XfinityWifi (Comcast) hotspot, which requires a Web Authentication log-in through the Captive Portal.
I don't get very good signal in my apartment, but the signal is there, just weak.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    No they can not connect to networks with web authentication.
    DarrenM
  • NETGEAR WiFi Range Extender EX2800 - WiFi Extender AC750 allows login through a captive login portal.
    • plemans's avatar
      You need something that supports wisp mode.
      Check into gl.inet's line of travel routers. They have wisp mode.
