kfall
Dec 04, 2015Aspirant
WiFi Extenders
I have a small business (6 computers) in which I setup the AC1450 Wi-Fi router. It works great and I have no issues EXCEPT there are a couple of computers that are behind a block wall and the signal tends to be weaker. I was looking at the AC750 Extenders and was wondering if they woulld be an appropriate solution. I read some of the reviews and there was mention of the bandwith being reduced if you are using these boosters. and that signals get dropped if you have a device that moves around (i.e. laptop, ipad) Are these real concerns? Is there a better solution?
Hi kfall,
If the rooms are in the same electrical circuit, consider Powerline:
http://www.netgear.com/home/products/networking/powerline/
Powerline setups:
Router---wire--Powerline(1a)---outlet room 1 ..... outlet room 2---Powerline(1b)---wire/WiFi---device
Here are some sample setups of Extender:
Router---wire---Extender - - - devices
Router - - WiFi - - Extender - - - devices - this method reduces the bandwidth by extending the router's signal through WiFi
- nhannNETGEAR Employee Retired
Hi kfall,
Powerline setups:
- kfallAspirant
Thanks for the reply. Unfortunatley they are not on the same circuit and now that I understand about bandwidth being less with the extenders I have decided to go another route - probably cables
