jtswat285's avatar
Dec 15, 2020
WIFI Extenders
Can both extenders be used in tandem?
  • plemans's avatar
    which extenders? a model helps?
    And how do you have them setup?
    I would highly recommend against daisy chaning them.
    Daisy chain:   router---->extender------>extender
    star would be prefered.
    star: extender<-------router------>router
    i usually recommend to people if they're needing more than 1 extender to move to a full mesh system like orbi versus trying to juggle mutliple extenders.
    • jtswat285's avatar
      jtswat285
      Tutor
      Thank you for the feedback. I have a 6150 and a 6120. I set them up using the WPS.
      • plemans's avatar
        Are you having issues setting them up? and if so, what are the issues?
