goldbergr
Oct 18, 2021Aspirant
WiFi extension between two cabins 50 ft apart
Hi, I'm looking for a solution to extend the WiFi range between two cabins, which are about 50 ft apart. Situation: Cabin 1 has the Smart Wifi Router, which is connected to the modem and bot...
Oct 18, 2021Guru - Experienced User
whats your budget? you have several options. A little depends on the temperature in your area. to hot/cold and outdoor connections will fail quicker or not work at all.
1. get a outdoor rated extender that is powered over POE. It'll also be able to use that connection to connect another access point to in the cabin.
2. Get a weather proof enclosure to put an extender in. This would open up the options to more devices.
3. Spend a little time and bury an underground rated ethernet cable. They're not expensive and they're going to give you the most throughput/reliable connection. They'll also be the cheapest option. (this would be the option I'd use)
4. get a access point that you can add antenna extensions to so you can put them outside the cabin (then you don't need to weather proof the access point. Then simply connect another access point to it via cable in the cabin for broadcasting in the cabin.
It all comes down to you'll need something external to the cabin to pickup the signal and then run a wire inside the cable to connect another device in the cabin for working on the inside. Or you simple take the time to bury the cable.
goldbergr
Oct 26, 2021Aspirant
Thanks for the ideas! Laying the cat-5 between the cabins isn't feasible without some structural modifications, but I'm trying your last idea to push the signal to the extender and then bringing inside cabin 2 with a cat-5 cable connected to another router.
- plemansOct 26, 2021Guru - Experienced User
Another option is a point to point system like netgear Airbridge.
There's cheaper options on amazon but it could get the signal there and then you can connect the access point to it.
