goldbergr
Oct 18, 2021Aspirant
WiFi extension between two cabins 50 ft apart
Hi, I'm looking for a solution to extend the WiFi range between two cabins, which are about 50 ft apart. Situation: Cabin 1 has the Smart Wifi Router, which is connected to the modem and bot...
goldbergr
Oct 26, 2021Aspirant
Thanks for the ideas! Laying the cat-5 between the cabins isn't feasible without some structural modifications, but I'm trying your last idea to push the signal to the extender and then bringing inside cabin 2 with a cat-5 cable connected to another router.
Oct 26, 2021Guru - Experienced User
Another option is a point to point system like netgear Airbridge.
There's cheaper options on amazon but it could get the signal there and then you can connect the access point to it.
