Emanchi's avatar
Emanchi
Wifi extension to metal building
I have a WGR614G54 router.   What's best way to get wifi inside building?  It's around 50 ft from house, and I get wifi just outside the building.   Electric panel in building is powered from a branch circuit in house main electric panel.  So if it helps, they're on the same electric circuit.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Emanchi
    If they are on the same power circuit you may want to look into some of our powerline adapters might be a better option than wifi extenders.
    DarrenM
    • Emanchi's avatar
      Emanchi
      I've looked at them.  Thanks for confirming this may be my solution.  Will advise how it works.
