KellyW0466
Nov 27, 2021Follower
WiFi Mesh Extender
Why does some of my devices show 5.0 ghz and others show 2.5 ghz on the mobile app? How do I connect all my devices to show 5 ghz?
If you're using the "One Wifi" feature, it allows devices to switch between the 2.4ghz and 5ghz as needed.
You can always disable that and choose which band to connect your devices to.
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you. - michaelkenwardGuru - Experienced User
KellyW0466 wrote:
Why does some of my devices show 5.0 ghz and others show 2.5 ghz on the mobile app? How do I connect all my devices to show 5 ghz?Not all devices work at 5 GHz.
