agripuppo
Jan 08, 2017Aspirant
wifi password
MODEL:EX3700-100PES
OS: WINDOWS 10
I HAVE INSTALLED THE EXTENDER FOLLOWING THE USER MANUAL INLCUDED AND CONNECTED WITH WPS TO MY ROUTER "FASTWEB TECHNICOLOR TG788VN V2" BUT WHEN I TRY TO CONNECT MY DEVICE TO ONE OF THE NEW EXTENDED WIFI NETWORK (_2GEXT AND _5GEXT) USING THE SAME ROUTER PASSWORD THE SYSTEM ANSWER "INCORRECT PASSWORD". ANY SUGGESTION?
Hello agripuppo
Try to go to www.mywifiext.net while connected to your router or via Ethernet connected to the extender and change the wireless password to what you want it to be then try to use the wireless.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello agripuppo
DarrenM
- agripuppoAspirant
Thank you, Darren, now all is OK!
