TDorwart
Sep 26, 2016Aspirant
Wifi range extender ethernet port not working
I just purchased a NETGEAR Nighthawk X4 AC2200 . The only reason I needed something like this was so I can add another Arlo HomeBase to another location in my house. I set it all up and all the sig...
DarrenM
Sep 28, 2016Sr. NETGEAR Moderator
Hello TDorwart
Have you checked the speeds of the extender are you getting the min speed you need for arlo to work?
DarrenM
TDorwart
Sep 28, 2016Aspirant
I called Netgear and they were no help. He even insisted that I hard reset my Extender, that is even before I was able to begin stating what the issue really was. All they wanted to do was forward me to ARLO tech support. Needless to say, he didn't help at all. Upon digging into it my self further I realized that I was having connectivity issues with my 5GHZ signal and that I had programed my ethernet to WIFI to route through that signal. I changed it and now works like a champ. I always go back to saying, if i need something done I need to do it myself. Thank you for your reply though, i really appriciate it!
