daneal2674
Sep 18, 2016Aspirant
WiFi range extender for WNDR3700v3
Would like to find the best Netgear range extender for my Netgear WNDR3700v3 wifi router. Any suggestions?
DarrenM
Sep 20, 2016Sr. NETGEAR Moderator
Hello daneal2674
This is up to your budget and what type of features you are looking for on a extender. Do you need any Ethernet ports or are you just looking for something simple to extend the wifi?
DarrenM
daneal2674
Sep 20, 2016Aspirant
Something inexpensive and simple. I do not need any extra ethernet ports. Just need to extend my wifi range.
- DarrenMSep 20, 2016Sr. NETGEAR Moderator
Hello daneal2674
If you have a 802.11 AC router I would suggest a Ex3700 if you have a 802.11 N router you may want to look at the Ex2700.
http://www.netgear.com/home/products/networking/wifi-range-extenders/?cid=wmt_netgear_organic
DarrenM
