EventMgmtProf
Jun 21, 2016Follower
WiFi Range Extender Model WN3000RP V1H2
Hi.....I have recently changed my home modem, yet my WIFI range extender is still registering the original modem which has been replaced. I have tried the factory reset, however this is not working. What should I do?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello EventMgmtProf
Make sure when you are doing a factory reset you are holding down the reset button for 10 seconds then it should let you do the setup again to connect to the new router.
DarrenM
