Insearch's avatar
Insearch
Follower
Oct 07, 2017
Wifi Range Extender no longer picks up signal
Wifi extender stopped picking up router signal weeks ago.  No signal, even after I moved it into the same room with the router.  I can't update the extender's software because not possible to get on the extender.  Help!  It worked for months before this.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Did you try to factory reset the unit by holding the reset button for 10+ seconds.
    DarrenM
