ninakristin
Mar 21, 2018Aspirant
Wifi range extender password issue
Hi there, we've purchased the above wifi rang extender in the hope to improve the wifi reception in our home but there's one huge issue, the device will not accept the password I personally set. For ...
jvasanth1984
Mar 21, 2018Virtuoso
Hi ninakristin,
Try the password of your existing network carefull as it is case sensitive. Check it in settings of your Router if you are not sure. Since its working via WPS, i'm sure its the bad password that you are trying.
ninakristin
Thanks for the suggesting the most obvious, trust me I have tried this at least 50 times over and over again. I am not using the factory password and rounter name my router came with - I have both customised to names/words that I have chosen. It picks up the customised router name for the ext which is the custom name of my chosen router name + ext but when it comes to my chosen password it does not accept it. I somehow have now managed to go into the router settings by going in via http://192.168.1.250 but when I look into the back end it says the ext has the same password as my router which clearly is not the case so I'm still stuck with the same issue which is getting rather irritating :(
- jvasanth1984Mar 21, 2018Virtuoso
Hi ninakristin,
I would recommend you to change it as custom password, but set it manually with same security and password on extender's wireless settings. Let me know if that helped.
