alecriley25
Mar 03, 2018Tutor
Wifi range extender won't accept router password
I appear to have installed my wifi range extender successfully using WPS setup. I have steady green light on router link LED, also extender is listed as being connected in the routers list of connect...
- Mar 05, 2018
Thank you
i have now solved my problem.
I found the extenders IP address in my routers list of connected devices.
I then put the extenders IP address into a browser.
followed on screen instructions to set up user account.
I then went into extenders WiFi setting and altered the extenders WiFi password.
jvasanth1984
Mar 04, 2018Virtuoso
Hi alecriley25,
I'm afraid if you are trying a wrong password. Please check the password from your Technicolor gateway and try the correct password. Hope, the below links can help you if you have a computer connected wireless to your Technicolor gateway.
https://kb.netgear.com/20046/How-do-I-check-the-wireless-passphrase-network-key-saved-on-my-computer
alecriley25
Mar 04, 2018Tutor
I thank you for your prompt reply. I have checked my router password as you advised using Windows 7, but it mearly confirmed what I already knew that I am Not using the wrong password.
I had already done a factory reset on my router and then reconnected all my devices to my router after first instructing them to "forget this router" before I posted my question, this can only confirm that the password is correct. The only time my password doesn't work is when I attempt to connect to my wifi extender.
- jvasanth1984Mar 04, 2018Virtuoso
Hi alecriley25,
In that case, I would request you to try reconfiguring the extender and check if it accept it. If you still come across the issue, let me know so that I can suggest appropriate steps.
- alecriley25Mar 05, 2018Tutor
Thank you
- jvasanth1984Mar 06, 2018Virtuoso
Hi alecriley25,
Good to know that it resolved your issue.
