alecriley25
Mar 03, 2018Tutor
Wifi range extender won't accept router password
I appear to have installed my wifi range extender successfully using WPS setup. I have steady green light on router link LED, also extender is listed as being connected in the routers list of connect...
- Mar 05, 2018
Thank you
i have now solved my problem.
I found the extenders IP address in my routers list of connected devices.
I then put the extenders IP address into a browser.
followed on screen instructions to set up user account.
I then went into extenders WiFi setting and altered the extenders WiFi password.
alecriley25
Mar 05, 2018Tutor
Thank you
jvasanth1984
Mar 06, 2018Virtuoso
Hi alecriley25,
Good to know that it resolved your issue.
