Mike001
Nov 18, 2018Guide
Wifi range extender won't accept router password
When the _ext appears on my imac wireless options and I click to connect it does not accept the router password, if I dont get an answer soon I will take it back and get a refund!
Nov 19, 2018Guru - Experienced User
Did you use my.netgear.com to access support?
It's a bad idea to google support numbers, there are sites out there that claim to be netgear support but aren't.
Mike001
Nov 19, 2018Guide
I thought it was Netgear but the lady was definately from India I think. I have since rebooted the extender as advised and my wireless network now shows Netgear_ext but I cannot establish a connection to the internet and now I am tired and must get something to eat.........Mike
- Mike001Nov 19, 2018Guide
My Imac wireless settings now identify the netgear_ext as a network and seems to connect but has no internet connection and shows different IP addresses for router and extender
- StephenBNov 19, 2018Guru - Experienced User
Yes. But you should be able to browse to www.mywifiext.net - that takes you to the web ui of the extender, not the internet.
- DickDukeNov 19, 2018Apprentice
Every device MUST have a different IP address. You may eventually want the same WiFi SID (name) but you never want to assign the same IP number to more than one device.
It’s normal that you can’t access the Internet from the extender at first. You need to configure the extender to connect to your router first. Only after the extender is set up to extend your existing WiFi network, will it connect to the Internet.
Ok, its all very well saying you can't connect at first but I would rather like it to connect whilst i am stll alive!
As I've said before, you first connect to NETGEAR_EXT and then browse to www.mywifiext.net. That gets you into the setup process where you link the extender to your router's wifi.
What happens when you do that? Are you
- not able to connect to NETGEAR_EXT?
- not able to browse to www.mywifiext.net?
- something else???
- schumakuNov 19, 2018Guru - Experienced User
Mike001 wrote:
My Imac wireless settings now identify the netgear_ext as a network and seems to connect ... shows different IP addresses for router and extender
This is because of your iMAC does get a different (virtual) MAC address when connected through the extender - that's how the Netgear wireless extenders are implemented, the community can't change that.
Mike001 wrote:
... but has no internet connection ...
Anything on your router prohibiting the Internet access for the other IP address?
Any default security like "do-not-allow-unknown-device-Internet-access" in place? - Mike001Nov 19, 2018Guide
No, I cannot connect to the internet when trying to connect the extender.............so I cannot log on using the extender
My router is a very simple device and I have never tried to connect to it other that use it for internet access
Assuming your primary wireless is not named netgear and/or you have not fixed the extender to serve as netgear_ext (the extenders default to the primary wireless name + _ext) it might indicate that it has indeed not connected to the router yet.
Hard to figure out why - permitting you have used the wireless security key (not the router administration password) to associate the extender.
Last, your router isn't one of these very simple ones allowing either 5 GHz or 2.4 GHz and it's configured for 5 GHz while the simple extender does support 2.4 GHz only? Or the router is that old that it does still use WEP keys (instead of WPA-TKIP and WPA2-AES)?
I am very grateful to all who have tried to help me with my problem (rather Netgear problem I think) and I feel that a solution will be forthcoming but for now I will give it a rest and try again tomorrow, Thanks again everyone..............Mike
- Mike001Nov 20, 2018Guide
I have just tried again to connect my extender to the router which seems to work but it still will not accept the main router wireless key and returns 'invalid password' message
I have just contacted my broadband provider and they confirm the router extender is connected to my router but still when I enter the password it comes back with 'invalid password'
- StephenBNov 20, 2018Guru - Experienced User
Mike001, you aren't giving us enough information to help you. About all we can tell is that something isn't working.
It would be helpful to know the wifi security mode your router is using. As schumaku says, you shouldn't be using WEP. Perhaps post the security mode here.
I can't tell if you only pressed WPS during the setup procedure, or if you tried the setup procedure without pressing WPS.
If you don't press WPS, you should be able to connect to the extender's wifi with no password. Then you can browse to www.mywifiext.net even though the extender isn't connected to the internet. That's because www.mywifiext.net is special - it's not on the internet, it's actually the web ui of the extender itself.
Can you please try to follow the non-WPS procedure, and be a bit more precise on where (and how) it fails?
- DickDukeNov 20, 2018Apprentice
Mike001, Can you tell us the make and model of your router? Also where the router is, and where the extender will be located within your home?
If your router is older, and your home is not huge, you might find it simpler to return the extender, and replace your router instead. The newer routers cover a lot more area than the older ones used to. Depending on your available budget, a Netgear Nighthawk router (even a slightly older model like the AC1900) will easily cover a small house or two bedroom apartment. If you have a bit more money to spend, any of the new Netgear Orbi models will give you great coverage if you buy the model designed for your home size.
Instructions were followed to the letter with the WPS setup and the broadband provider confirmed the extender was connected to the router. I have not tried the setup without using WPS. My router uses a 'wireless key' code.
As a 'last resort' I will try the setup with no wps tomorrow.
Again, many thanks for the helpful responses.
I have a technicolor gateway router
- Flicker123Apr 30, 2019Aspirant
How about offering some practical help?
Mikr001 - you deserve a medal for your persistence. I have given up and returned the extender to the seller. I'llbuy something that actually works.
