Mike001
Nov 18, 2018Guide
Wifi range extender won't accept router password
When the _ext appears on my imac wireless options and I click to connect it does not accept the router password, if I dont get an answer soon I will take it back and get a refund!
schumaku
Nov 19, 2018Guru - Experienced User
Assuming your primary wireless is not named netgear and/or you have not fixed the extender to serve as netgear_ext (the extenders default to the primary wireless name + _ext) it might indicate that it has indeed not connected to the router yet.
Hard to figure out why - permitting you have used the wireless security key (not the router administration password) to associate the extender.
Last, your router isn't one of these very simple ones allowing either 5 GHz or 2.4 GHz and it's configured for 5 GHz while the simple extender does support 2.4 GHz only? Or the router is that old that it does still use WEP keys (instead of WPA-TKIP and WPA2-AES)?
Mike001
Nov 19, 2018Guide
I am very grateful to all who have tried to help me with my problem (rather Netgear problem I think) and I feel that a solution will be forthcoming but for now I will give it a rest and try again tomorrow, Thanks again everyone..............Mike
- Mike001Nov 20, 2018Guide
I have just tried again to connect my extender to the router which seems to work but it still will not accept the main router wireless key and returns 'invalid password' message
I have just contacted my broadband provider and they confirm the router extender is connected to my router but still when I enter the password it comes back with 'invalid password'
- StephenBNov 20, 2018Guru - Experienced User
Mike001, you aren't giving us enough information to help you. About all we can tell is that something isn't working.
It would be helpful to know the wifi security mode your router is using. As schumaku says, you shouldn't be using WEP. Perhaps post the security mode here.
I can't tell if you only pressed WPS during the setup procedure, or if you tried the setup procedure without pressing WPS.
If you don't press WPS, you should be able to connect to the extender's wifi with no password. Then you can browse to www.mywifiext.net even though the extender isn't connected to the internet. That's because www.mywifiext.net is special - it's not on the internet, it's actually the web ui of the extender itself.
Can you please try to follow the non-WPS procedure, and be a bit more precise on where (and how) it fails?
- DickDukeNov 20, 2018Apprentice
Mike001, Can you tell us the make and model of your router? Also where the router is, and where the extender will be located within your home?
If your router is older, and your home is not huge, you might find it simpler to return the extender, and replace your router instead. The newer routers cover a lot more area than the older ones used to. Depending on your available budget, a Netgear Nighthawk router (even a slightly older model like the AC1900) will easily cover a small house or two bedroom apartment. If you have a bit more money to spend, any of the new Netgear Orbi models will give you great coverage if you buy the model designed for your home size.
Instructions were followed to the letter with the WPS setup and the broadband provider confirmed the extender was connected to the router. I have not tried the setup without using WPS. My router uses a 'wireless key' code.
As a 'last resort' I will try the setup with no wps tomorrow.
Again, many thanks for the helpful responses.
I have a technicolor gateway router
- Flicker123Apr 30, 2019Aspirant
Mikr001 - you deserve a medal for your persistence. I have given up and returned the extender to the seller. I'llbuy something that actually works.
