Mike001
Nov 18, 2018Guide
Wifi range extender won't accept router password
When the _ext appears on my imac wireless options and I click to connect it does not accept the router password, if I dont get an answer soon I will take it back and get a refund!
DickDuke
Nov 18, 2018Apprentice
Each device has its own password. You need to configure them before they will work together. Follow the directions step by step, and it will probably work. You'll also most likely find the configuration login for your extender in tiny print on the back or bottom of the unit.
Search for the solution to specific problems by using your device model numbers.
Flicker123
Apr 30, 2019Aspirant
RTFM - the booklet says enter your wifi password not look for an alternative password. I do this and it is not recognised. There is no password on the device itself.
