GRANBOB
Feb 05, 2017Aspirant
WiFi Range Extender
I am having trouble connecting my range extender to my new telstra nbn router TG799ua . is my exteneder compatible with a testra nbn router
GRANBOB
Feb 08, 2017Aspirant
THANKS FOR YOUR REPLY
THE MODEL NUMBER IS WN2000RPT
THE PROBLEM IS THAT I CAN CONNECT THE EXTENDER TO THE TELSTRA MODEM USEING THE WPS METHOD
2 GREEN LIGHTS COME ON THE EXTENDER
WHEN I GO TO MY PHONE TO CONNECT BY WIFI I CAN CONNECT TO THE EXTENDER AND THE THIRD LIGHT COMMES ON AFTER APPROX 1 MINIUTE THE GREEN LIGHT IS REPLACED WITH A RED LIGHT AND I LOSSE WIFI CONNECTION
REGARDS
BOB TRACEY
DarrenM
Feb 09, 2017Sr. NETGEAR Moderator
Hello Grandbob
Have you tried to connect with the manual way?
DarrenM
