GraniteKnoll's avatar
GraniteKnoll
WiFi Range
Can you connect more than one range extender to the same router?
  • plemans's avatar
    You can.
    I'd recommend doing it in a star pattern and not daisy chained though.
    Star: extender<--------router------->extender
    daisy chain: router------->extender------>extender
    reason why is standard extenders take a 50% speed hit just based off how they function. So by the 2nd hop, its best possible speed is 25% of what the router has.
