aubylife
Jan 22, 2018Guide
Wireless connects but no internet
It used to work without problem, but not now.
EX7300 worked fine with Netgear router r7000 in the past time until r7000 died. And Paired EX7300 with the new router from ASUS. It worked at the beginning but lost internet connection totally now.
Factory Reset and reset-up is not helpful at all. It can be found ip (sometimes ip is gone) and can connect to the router, but still no internet.
Iphone can found its _ext network, but it shows no internet connection whatever how to set up the EX7300.
what is wrong with it?
1 Reply
- jvasanth1984Virtuoso
Hi aubylife,
Try to setup the extender with correct password for your new router. Do modify wireless channel on router if required. Also, check for firmware upgrade for your EX7300.
