billsav
Apr 09, 2022Aspirant
Wireless printer not working over extender
Bought a Netgear AX1800 Mesh Extender to improve wifi signal in my house.Works fine with computers, but the wireless printer won't work. (HP 4500 all-in-one). I've done enough research to realize th...
michaelkenward
Apr 10, 2022Guru - Experienced User
Which one? AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds and technology.
Look at the label on the device for the model number.
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
Re: Nighthawk Router not connecting to HP printer - NETGEAR Communities
Then there is this:
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
- billsavApr 11, 2022Aspirant
Thanks for taking the time to reply.
1. You asked about he model. I was puzzled about the model name, too. When I looked at the bottom of the machine, this is how it describes the model: "EAX20 — 4-Stream AX1800 WiFi Mesh Extender" - I note that this doesn't show up in the drop down menu, so that is also confusing. I believe it is part of the Nighthawk series but I don't have the box info anymore.
2. Regarding HP software. I've been all over the HP site, using their troubleshooters, downloading the software, reinstalling drivers, etc. None of that has helped. However:
- I can print from a UBS port (so the computer has the right driver)
- I can see that the printer is on the wireless network with its own IP address
- I can add the wireless printer when the computer and printer are connected to the main router (Comtrend router/modem)
- But when I get to my office, which is connected on wifi via the Netgear extender, the computer gives me an error message that the computer cannot find the driver.
3. Why I'm on the Netgear site: This may be an HP software problem, but I hit a dead end with HP. I'm puzzled that the setup works with the wifi signal through the router/modem but not through the Netgear extender. My conclusion is that either the extender is doing something that confuses the software or the software can't figure out how to work through the extender (chicken/egg?). Either way, I was hoping there might be some kind of workaround via the extender settings.
If as you say, all the extender is doing is broadcasting a signal, then I'm doubly puzzled why I can see the printer by typing it's IP Address in the web browser, but the computer cannot recognize that it has the driver for the same printer.
- michaelkenwardApr 11, 2022Guru - Experienced User
The drop-down options are poor. But it may not help that your message is in the Powerline Networking section. (I will move it.) The EAX20 is a wifi extender.
EAX20 | WiFi Range Extender | NETGEAR Support
I can see that the printer is on the wireless network with its own IP addressI am a Canon user. It has a utility that I can throw at the network to find and connect a printer. Unfortunately, I am not familiar with HP's way of doing things beyond seeing a steady flow of "my HP printer won't work" messages here.
I can add the wireless printer when the computer and printer are connected to the main router (Comtrend router/modem)Have you tried adding the printer to the EAX20?
Do other wifi clients play nicely with the EAX20?
Thanks for clarifying about the forum. Didn't realize I was in the wrong place. Apologies!
And, yes, the best solution might be to dump the HP and go for Canon. : -(
