totok
Mar 12, 2016Aspirant
Wireless Printing Using WiFi Range Extender and Ethernet Print Server
I already have a NetGear EX2700 WiFi range extender. Can my PC connect wirelessly to EX2700, where the EX2700 connect to D-Link DPR-1020 print server (wired), to perform printing to a USB printer? ...
- Mar 13, 2016
Your setup doesn't show a router. You need one to assign IP addresses via DHCP.
PC ---(WiFi)---> NetGear EX2700 ---(Ethernet)--->DPR-1020 ---(USB)---> Printer
|RouterYour setup may work without a router provided that the PC or print server are manually configured with static IP address.
TheEther
Mar 13, 2016Guru
Router
totok
Mar 13, 2016Aspirant
I'm using a router actually, sorry for not showing it in the diagram. Thank you for the enlightment.
