Shingen
Mar 04, 2019Aspirant
Wireless Printing
Hi Members,
I'm experiencing an annoying problem with my EX6120.
I have no difficulty in the operation of the PC connected to the extender, but the problems come with the connection of a printer ...
- Mar 12, 2019
Hi Shingen,
Thank you for confirming. A few more things:1. Make sure the printer is set to DHCP and not a static IP.
2. Can the printer be wired to the extender? If so, give that a try and let us know the outcome.
3. Are there any other devices connected to the extender? If so, are they experiencing any issues?
~Christian
Christian_R
Mar 07, 2019NETGEAR Employee Retired
Hello Shingen,
A couple things:
1. Does the printer show up as an attached device on the fastweb modem?
2. If so, can the printer be pinged from the PC?
~Christian
- ShingenMar 08, 2019Aspirant
Thanks Christian!
1. Yes, it does
2. Yes, the printer can be pinged
- Christian_RMar 12, 2019NETGEAR Employee Retired
Hi Shingen,
~Christian
- ShingenMar 13, 2019Aspirant
Thanks Christian!
DHCP was the problem!
