Interneti
Jan 01, 2018Follower
WLAN connection onyl when switching on/off my WN30000RP Extender
Hi,
I have an UPC cabel router and to ensure that the whole apartment I am using a WN3000RP extender since many years.
It works fine for me. The only issue I have is, that when UPC provider has internet connection interuptions I have to restart the rooter again. From that moment the WN3000RP does not work automatically or does not connect again automatically with the router.
I have to restart also always the WN3000RP. For me it would be much easier, if the WN3000RP can connect with the router always automatically. Is there a possibility in the settings that the WN3000RP connection with the router will be executed automatically?
Many thanks for your support and best regards.
Andreas
1 Reply
- jvasanth1984Virtuoso
Hi Interneti,
Check for firmware upgrade on extender and try to modify wireless channel on your router if issue persist.
