hhv
Sep 25, 2015Aspirant
wn 2000 rptv2 error message saying password is not correct on _ext ssid.
When I enter the correct wifi password from my xfinity home network, (16 digits long) I get an error message saying the password is incorrect. When I connect via the regular ssid (without the _ext) i...
Babylon5
Sep 25, 2015NETGEAR Employee Retired
Does the xfinity password use simple alphanumeric characters or are there other symbolic characters used also? Would you mind posting the password here?
- hhvSep 30, 2015Aspirant
There are only alphanumeric characters used in the password.
- nhannOct 01, 2015NETGEAR Employee Retired
Is this a first time setup for the WN2000RPTv2?
When setting up the extender to connect to your router, is the security option matching the one being used on your router? (e.g. WPA2)- hhvOct 01, 2015Aspirant
No this is not the first setup I have changed the network name. New carrier.
I cannot access the NETGEAR device to see about the security because I cannot enter the password.
Is there a limit to the length of the password? My new device has a 16 character passwrod name.
