denisvh's avatar
denisvh
WN1000RP and PEAP
Trying to use the wn1000RP wifi amplifier with a WPA2 - enterprise PEAP network. Authentication of the user by user ID and password.
This fails.
The devices sees the network as a wep network (this is worong).
Is there any way to use it with this kind of network ?
Thanks.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello denisvh
    Have you tried to use the WPS method or does the main router not have WPS?
    DarrenM
    • denisvh's avatar
      denisvh
      I do not own the router. I know that it's a PEAP one because I could connect several devices to it, and this connection was always a PEAP connection, no other way availble for security reasons.
      So the only devices able to get connected to this device are PEAP compliant.
      This does not seem to be the case for the WN1000RP but I wanted to be sure about that.
      Thanks.
