PCSB
Jan 06, 2016Aspirant
WN1000RP connecting to wrong network
I've had a WN1000RP booster for a couple of years and it's always worked perfectly - until yesterday. Suddenly, instead of maintaining its connection to my router, it's showing up as an extension t...
Retired_Member
Jan 06, 2016try changing channels on your router
- PCSBJan 06, 2016Aspirant
Many thanks for the suggestion - but I think I've somehow solved the problem. Though I'd reset the booster a number of times, I did so again while it was plugged in and that seems to have done the trick as it's now connecting to the router and boosting its signal as before.
Perhaps I should have reset the booster that way in the first place, but at least normal service now seems to have been restored.
