kenrw8
Dec 28, 2013Follower
WN1000RP does not work2
These Extenders are C**P on second one and again followed instructions i.e plug in, press WPS button, press WPS on router (Netgear DGND3700) waited, entered router SSID and password (manually as it does not appear in SSID found list)
No internet , No link led, I've done factory reset , tried again and again they don't work don't waste your time buying.
Sending email to Netgear complaining of the rubbish their selling.
- Vickie05AspirantI need to set it up to my new internet
- DarrenMSr. NETGEAR Moderator
Hello Vickie05
Here is a link to a guide on how to setup the extender
http://kb.netgear.com/app/answers/detail/a_id/22703
DarrenM
- storm_2003NovicePlease provide screenshots on the Extender Status page found on the UI.
- PishawAspirantSo your solution is a link to the instructions? Good lord. The instructions work fine. It's the EXTENDER that doesn't work. Everything in the setup goes fine until you try to connect to the extender after establishing the network. At that point, it will allow NOTHING to connect to it. Is the WN 1000RP trash by design?
- ToolheadAspirantMake sure that the wifi that you are extending is on channel 10 or below, the extender will not detect channel 11, 12 or 13
- FairytailVirtuoso
